Warning node Pick Point
Hi @Paolo_Emilio_Serra1 ,
I use node Pick point, but it was warning…
Can you help me.
Thanks in advance…
It could be that the node is deprecated on newer versions of dynamo
Hi
You can try this one here, it should work
@lebinhx3c2012 it’s a known “issue” with an empty project and running mode on automatic
I select the pick point node for is input, but in the Dynamo Player I can’t select the pick point.image
Thanks for your answer, But I am using node for Civil3d
