Where is this database warning file (.csv)?
final step regarding list.map does not work,why?
the last map creates “Null”
GetAndManageWarnings.dyn (72.3 KB)
KR
Andreas
KR
Andreas
Hey Andreas,
So, for the first, I suspect this is as discussed by Konrad here… https://archi-lab.net/digging-through-revit-warnings-to-find-meaning/
It is possible to extract all the (900?) warnings from revit, but most don’t have a rating and it’s not necessarily the rating you want it to have…
So I think you want to have your own .csv file, here’s mine (I can’t upload .csv so I renamed to .txt) it doesn’t catch all of them, but most that you’ll regularly come across.
CurrentWarningRatingLibrary.txt (11.8 KB)
For the second, I think this might be better?
Hope that helps,
Mark
I think under headers are the imputs listet. But it does not work
Excel export does not work ![]()
You’ve got way too many list levels in your data input. I don’t know what structure that node expects but I would assume it’s similar to excel with a list of lines with sublists of separated values.
Right, but as you can see in the CSV output, it’s expecting a @L3 list structure. You’re providing @L5. The data structure should be
@L3 = full dataset
@L2 = line/row
@L1 = value
hmmm… just flatten?
Probably not, based on your previous image. It should look just like the example structure you wrote above the AddItemToFront node.
That’s the part that was throwing me off in your other image. I don’t know where you’re adding the headers. It should look like the Flatten output (looks like you were right there) but with the headers added to the front.
i think the aim is like this:
the problem is it takes the headers as a list and not as headers.
the “headers” are not headers ![]()
it is still cero? what could be the error?
…it looks likes in your pic the dynamo output
it is not sorting it well when i link the .csv
Look at my list structure again. You don’t want to transpose the data. The data should have the same index as its respective header. If you have 5 headers then you should have 5 items in each sublist to match those headers.
You have right something is to much here. Transpose and map and listdepth.
it is made for excel. I got confused.
this List.AddItemtoFront looks correct @L3 is full data @L2 is Lists that contain → @L1 is the data (category, warnings,…)
Just get rid of the Transpose after the Flatten.
It works a lot better! the csv export is not clean:
That could be from your original list structure. You did a lot of transposing there which is what initially worried me. Can you confirm that everything looks right in Dynamo?
Make sure you check specifically for x==5 but it looks good otherwise. Do you have any commas in those strings? The node will write the data to a comma delimited file but Excel will still parse for commas on its own when reading the csv. That’s a tricky part of handling these kinds of files. Manual cleanup may be the only option at that point.
