Want to play a sound when script is done
How can i play a sound at the end of my script…
Personally I use the following python snip:
import winsound
duration = 2500  # millisecond
freq = 440  # Hz
winsound.Beep(freq, duration)
OUT = "Success"
Setting a simple “dummy”-input from the end of your graph will delay the sound till that portion of the graph have run.
and if i want to run an mp3…
Apart from writing a C# script with the song I do not believe that is possible using the IronPython shell.
May I ask why you require the ability to play a mp3 on completion?
My best guess … he’s proud of his script :muscle:
we have very complex drawings, printing drawings can take up to 40min to complete…i made a script that handles the printing, but i wan’t an audio file to make notice that the printing is done.
and running an mp3 is then just fun…
but i must be possible to just run a file…
You can make your computer talk giving the user a talking heads-up :slight_smile:
clr.AddReference('System.Speech')
from System.Speech.Synthesis import SpeechSynthesizer
speechSynthesizer = SpeechSynthesizer()
speechSynthesizer.SpeakAsync("Your graph have now finished making awesome drawings")
Hi Arno,
This ought to open any file with the default application:
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import System
import os
OUT = os.startfile(r"C:\Taco\music\De Kift - Bal\01 Bal.mp3")
You can use SoundPlayer to play .wav files.
from System.Media import SoundPlayer
sp = SoundPlayer()
sp.SoundLocation = “C:\my.wav”
sp.Play()
And here is something to play if the Dynamo graph needs help :slight_smile:
import winsound
import time
f1 = 800
f2 = 800
d1 = 110
d2 = 210
s1 = 0.3
s2 = 1.2
for i in range(0,4):
	winsound.Beep(f1, d1)
	time.sleep(s1)
	winsound.Beep(f2, d2)
	time.sleep(s1)
	time.sleep(s2)
OUT = "Success"
Ah, good old winsound… My favourite…
@Jonathan.Olesen , thank you for this! Can you help me get this to work in Dynamo 2.13 using CPython3?
I’m getting an error stating: FileNotFoundException : Unable to find assembly ‘System.Speech’. at Python.Runtime.CLRModule.AddReference*String name)[’ File “< string >”, line 13, in < module >\n’]
Here is my current code:
Blockquote # Enable Python support and load DesignScript library
Blockquote# The inputs to this node will be stored as a list in the IN variables.
speachstring = IN[0]
Blockquote# Place your code below this line
from System.Threading import Thread
Thread.Sleep(2000)
clr.AddReference(‘System.Speech’)
speechSynthesizer.SpeakAsync(speachstring)
Blockquote# Assign your output to the OUT variable.
OUT = 0
