Wall Spiting by distance
All
How to split Wall given by distance in dynamo.
Pleas give me a suggestion or any other ideas
you can not split walls with dynamo
but you can create new walls
see topic:
Thanks for your reply
but i want split wall.
What Nico is syaing is that there’s no “Cut” node but you can change properties and crete new walls.
Okay
thanks for Guide me
This should get you started. It extracts the wall location line and divides it hten creates new walls.
divide wall into shorter walls.dyn (16.9 KB)
can i delete the first wall after segment of the wall???
yes you can
with the node Element.delete
i try but every wall are delete.
put a Passthrough node after you create the new walls
input in passThrough is the original wall
input in waitFor are the new walls
it’s not working
any other ideas
post a picture please
see
you have nothing selected :wink:
i select wall then create a new segment wall after that all walls are delete.
so you can look at this image
turn of automatic mode :wink:
run in manual mode
and use the elements.Delete from archilab
Great :+1:
yes it’s working now
Thanks for help me
If a comment solved your problem, please mark it as solution so others who have your problem can easily find a solution (and maybe leave a like here and there).
i can try this program for slanted wall.
Wall segment is not parallel to slope of wall, it’s create a rectangle shape not a slanted wall as first wall.
How can i fix this issue???
Start a new Topic with another description please
