I have generated walls by face first with family instance with generic model because with conceptual mass it does not recognize the faces. Create the walls without any problem; however, these walls are not editable for some reason. When generating wall by face from revit in the generic model it creates a usual wall without any problem, but when it is done from dynamo I cannot edit it. I don’t know what the problem will be. Thanks in advance.
@mikechamorro28 , hi
Walls which are created by face, they are hosted by the face. You can change the form of the host and refresh the wall.
KR
Andreas
try to get projected surface, perimeter lines, create wall out of that
There are known to be other ways to create walls, but it’s not what I require. Creating walls by faces is the query in this topic.
