Wall Hosted Receptacles (Continued)
Receptacle Placement.dyn (12.7 KB)
Custom nodes have been labeled
-Lunch Box for Dynamo Package (2017.10.4)
-Spring Nodes Package (132.2.8)
-Steam Nodes Package (1.2.4)
Here is my script for this face-based automation.
Wall and 2 Bed Offset Outlet 2021.dyn (119.9 KB)
Which package do you use for the node ā€œGet Documentsā€ and ā€œElements.Getlinkedfileā€
ā€œGet Documentsā€ was an out of the box node.
I see in 2021 it is now red and in an unresolved state.
ā€œElement.GetFromLinkedFileā€ is from the Steam Nodes package as noted.
If you right click on a node and then click ā€œhelpā€ it will show you if it came from a package
Most of my scripts are labeled right at the node.
Hey how did you get the elements to array on top of each other? By any chance can you send the dyn file that your using in the picture here.
I will dig through my files and send you my ā€œin-progressā€ script.
I was able to create a wall spacing placement, but Dynamo set them horizontal instead of vertical. I could never figure out why.
I don’t if this is going to make any sense, but I’m trying to use this script to see instead of placing outlets on to walls I’m trying to place sheathing nails on all sides of my studs that I’m working with. Do you have any idea of how I should go about that?
Script
