we try to detach all walls in a projekt from top/base.
The parameter “Top is Attached” is read only.
Is there a way to detach all wall with dynamo.
Here is what we got :
Hi Johannes,
Unfortunately it is not possible to access read only parameters (Top is Attached…) in Revit API due to its limitations.
Thank´s KULKUL,
so there is no way to do it.
Delete and reload is the only way to detach the elements.
Johannes
