Visualization of Deviation between Point Cloud and BIM
The Revit API has methods for retrieving points from a point cloud instance (filtered around a plane list).
A simple solution (though not necessarily very accurate) :
  1. Obtain the points on the face with PointCloudInstance.GetPoints().
  2. Then, if there are any, compare the UV coordinates of the center of a face with the average UV coordinates from the point clouds.
cloud_points_analysis_VS_Walls_2
Python code (works only with PythonNet3 or IronPython3, due to the use of Linq extensions)
Code
import Autodesk.DesignScript.Geometry as DS
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
# Revit API
from Autodesk.Revit.DB.Analysis import *
from Autodesk.Revit.DB.PointClouds import *
# Current Revit document
def view_prepare(view):
    Prepare the given 3D view for analysis visualization.
    Parameters
    view : Autodesk.Revit.DB.View
        The Revit view where analysis results will be displayed.
    # Try to find existing analysis display style by name using a collector and LINQ predicate
    analysisDisplayStyle = FilteredElementCollector(doc).OfClass(AnalysisDisplayStyle)\
                            .FirstOrDefault(System.Func[DB.Element, System.Boolean](lambda x : x.Name == "Paint_Preview"))
    if view.AnalysisDisplayStyleId == ElementId.InvalidElementId or analysisDisplayStyle is None :
        coloredSurfaceSettings = AnalysisDisplayColoredSurfaceSettings()
        coloredSurfaceSettings.ShowGridLines = False
        colorSettings = AnalysisDisplayColorSettings()
        legendSettings = AnalysisDisplayLegendSettings()
        legendSettings.ShowLegend = False
        analysisDisplayStyle = AnalysisDisplayStyle.CreateAnalysisDisplayStyle( doc, "Paint_Preview", coloredSurfaceSettings, colorSettings, legendSettings )
        view.AnalysisDisplayStyleId  = analysisDisplayStyle.Id
        # Commit transaction
def color_face_analysis(view, lst_face_analysis):
    Color faces in a view using Spatial Field Manager analysis results.
    Parameters
        Target view for spatial field analysis coloring.
    lst_face_analysis : list[tuple]
        Iterable of (face, face_ref, is_align_to_pts_cloud) where:
        - face : Autodesk.Revit.DB.Face
        - face_ref : Autodesk.Revit.DB.Reference
        - is_align_to_pts_cloud : bool, True if points are aligned to the face.
    sfm = SpatialFieldManager.GetSpatialFieldManager(view)
    if sfm is None:
        sfm = SpatialFieldManager.CreateSpatialFieldManager(view, 1)
    # Clear previous primitives
    sfm.Clear()
    # Register a result schema once
    resultSchema = AnalysisResultSchema("Schema Name" , "Preview_Selection")
    schemaIndex = sfm.RegisterResult(resultSchema)
    # Iterate faces to create/update spatial field primitives
    for face, face_ref, is_align_to_pts_cloud in lst_face_analysis:
        idx = sfm.AddSpatialFieldPrimitive(face_ref)
        uvPts = List[UV]()
        bbuv = face.GetBoundingBox()
        uvPts.Add(bbuv.Min)
        uvPts.Add(bbuv.Max)
        pnts = FieldDomainPointsByUV(uvPts)
        if is_align_to_pts_cloud:
            doubleListA = List[System.Double]([0.0])
            doubleListA = List[System.Double]([10.0])
        vals = FieldValues(List[ValueAtPoint]([ValueAtPoint(doubleListA), ValueAtPoint(doubleListA)]))
        sfm.UpdateSpatialFieldPrimitive(idx, pnts, vals, schemaIndex)
toList = lambda x : x if hasattr(x, "__iter__") and not isinstance(x, (str, System.String)) else [x]
# Inputs from Dynamo
point_cloud = UnwrapElement(IN[0])
tf = point_cloud.GetTransform()
lst_walls = toList(UnwrapElement(IN[1]))
threeDview = UnwrapElement(IN[2])
# Parameters controlling point sampling and tolerance
margin_factor_box = 0.05
averageDistance = 0.1
numberOfPoints = 2000
outPoints = []
debug = []
analysis_faces = []
view_prepare(threeDview)
for wall in lst_walls:
    bbx_wall = wall.get_BoundingBox(None)
    line_wall = wall.Location.Curve
    for layerType in [ShellLayerType.Interior, ShellLayerType.Exterior]:
        # create planes on each faces (6 faces)"
        Iplanes=List[DB.Plane]()
        ref_face = DB.HostObjectUtils.GetSideFaces(wall, layerType).First()
        face = wall.GetGeometryObjectFromReference(ref_face)
        bbox_uv = face.GetBoundingBox()
        center_uv = (bbox_uv.Min + bbox_uv.Max) / 2.0
        origin = face.Evaluate(center_uv)
        faceNormal = face.FaceNormal
        planeA = DB.Plane.CreateByNormalAndOrigin(faceNormal.Negate(), origin + faceNormal * margin_factor_box)
        planeB = DB.Plane.CreateByNormalAndOrigin(faceNormal, origin - faceNormal * margin_factor_box)
        Iplanes.Add(planeA)
        Iplanes.Add(planeB)
        planeC = DB.Plane.CreateByNormalAndOrigin(XYZ(0,0,1), bbx_wall.Min)
        planeD = DB.Plane.CreateByNormalAndOrigin(XYZ(0,0,-1), bbx_wall.Max)
        Iplanes.Add(planeC)
        Iplanes.Add(planeD)
        planeF = DB.Plane.CreateByNormalAndOrigin(line_wall.GetEndPoint(0), line_wall.Direction)
        planeG = DB.Plane.CreateByNormalAndOrigin(line_wall.GetEndPoint(1), line_wall.Direction.Negate())
        Iplanes.Add(planeF)
        Iplanes.Add(planeG)
        pcf = PointCloudFilterFactory.CreateMultiPlaneFilter(Iplanes)
        points = point_cloud.GetPoints(pcf, averageDistance, numberOfPoints)
        xyz_pts = List[XYZ]([tf.OfPoint(XYZ(p.X, p.Y, p.Z)) for p in points])
        # Linq conversion
        # XYZ -> IntersectionResult -> filter by distance -> DB.UV
        uvPoints = xyz_pts.Where(System.Func[DB.XYZ, System.Boolean](lambda pt : abs((pt - origin).DotProduct(faceNormal)) < averageDistance))\
                            .Select[DB.XYZ, DB.IntersectionResult](System.Func[DB.XYZ, DB.IntersectionResult](lambda pt : face.Project(pt) ))\
                            .Where(System.Func[DB.IntersectionResult, System.Boolean](lambda interR : interR is not None))\
                            .Where(System.Func[DB.IntersectionResult, System.Boolean](lambda interR : interR.Distance < averageDistance))\
                            .Select[DB.IntersectionResult, DB.UV](System.Func[DB.IntersectionResult, DB.UV](lambda interR : interR.UVPoint ))\
                            .ToList()
        # there are not enough points
        if len(uvPoints) < 100:
            analysis_faces.append([face, ref_face, False])
            # Linq aggregate function to compute sum and average UV
            sum_uv = uvPoints.Aggregate[DB.UV, DB.UV](
                                            UV.Zero, # accumulate init UV
                                            System.Func[DB.UV, DB.UV, DB.UV](
                                                        lambda acc_uv, next_uv:  acc_uv + next_uv
            average_uv = sum_uv / len(uvPoints)
            analysis_faces.append([face, ref_face, center_uv.DistanceTo(average_uv) < 2 ])
color_face_analysis(threeDview, analysis_faces)
