I am trying to scale and move the modelspace target location on already created viewports in multiple layouts. I used the AutoCAD API viewport class properties. I don’t get any errors when using these to edit viewports, however the locked and scale function work but the viewports aren’t being moved. I have attached my python code.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
viewports = IN[0]
scale = IN[1]
centerpoints = IN[2]
locked = IN[3]
if locked == None:
bool = True
bool = locked
out = []
ed = adoc.Editor
if len(viewports) != len(centerpoints):
out = "WARNING: Viewports and Centerpoints do not match length"
for i, viewport in enumerate(viewports):
vp = viewport.InternalDBObject
vp.UpgradeOpen()
cntr = centerpoints[i]
pt = Point3d(cntr.X,cntr.Y,0)
midpoint = vp.CenterPoint
midPnt = Point2d(midpoint.X,midpoint.Y)
ed.SwitchToModelSpace()
view = ViewTableRecord()
view.IsPaperspaceView = True
view.CenterPoint = midPnt
ed.SetCurrentView(view)
ed.SwitchToPaperSpace()
vp.CustomScale = scale
vp.ViewTarget = pt
vp.Locked = bool
vp.On = True
out.append(vp)
OUT = out
