Alien
1
This seemed to be working, but now it’s not.
As you can see the view title locations all have a different X position relative to their views.
When I originally tested it the x, y coordinates seemed to be relative to the viewports.
Also. The locations are also wrong:
What am I doing wrong?
More info on view label location here: ApiDocs.co
Alien
3
OK, you can see they should all be the same offset.
But they’re not. Hence my confusion. Any idea what’s going on?
That is odd. I am just using that API method in my node, so no funny business. Maybe change the lacing to longest?
Alien
5
Nope, that had no effect.
At least the length bit is working
It was working… but then I added the keyplan and it’s not.
But I’ve checked all the lists, flattened them, checked lengths etc etc.
They’re not being placed on the sheet in the right place either.
I’ve set the coords so the elevations are in a square an the keyplan is up a bit… But they’re all over the place.
Alien
6
ok… must have been list lacing.
I made a list with the coords going 5x and it’s worked.
But… I played with the moosing list lacing I swear.
Thanks for the suggestion though, it’s what fixed it (kinda).
Weirdly that’s fixed the viewport locations too.
Alien
7
Arrgh… It worked… but now it’s not.
Some days I really, really dislike Dynamo.
EDIT… the issue was between the chair and the keyboard.
I’d made the lists the wrong length again.
