Dear All,
I am trying to get vertices of a bunch of wires.but getting an error which says
File “”, line 55, in
TypeError: ‘Func[object, object]’ object is not subscriptable…
Any help?
import sys
clr.AddReference('RevitAPI')
clr.AddReference('DSCoreNodes')
from DSCore.List import Flatten
from Autodesk.Revit.DB.Electrical import*
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import System
clr.AddReference("RevitAPI")
import collections
from itertools import combinations
from itertools import product
WireList = UnwrapElement[IN[0]]
VertexList = []
for W in WireList:
vertexpoints = []
vertexpoints = W.GetVertex()
VertexList.append(vertexpoints)
OUT = VertexList
Im not if this is the error, but for the UnwrapElement function you should use parentheses not square brackets.
This could cause an error?
When troubleshooting code try to go through each step at a time and set the OUT value first to 'Wirelist". If this goes through fine, you can keep going through each variable you define, to see if you get the expected result.
