Create electrical wire from linesCreate electrical wire from lines
hai.
anyone help me how to Create electrical wire from lines in Revit dynamo have created chamfare wire but i have to convert the line to electrical wire
hi
there is a code in revit api we can use it
api
i have for this example two socket with detail lines between them
this is my sample code you code start from it
the main code:
clr.AddReference('System')
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB.Electrical import *
import System
app = uiapp.Application
wiretypeid=UnwrapElement(IN[0]).Id
viewid=UnwrapElement(IN[1]).Id
wiringtype= UnwrapElement(IN[2])
verpt= UnwrapElement(IN[3])
sconn= UnwrapElement(IN[4])
econn= UnwrapElement(IN[5])
verptxyz=[]
for v in verpt:
	verptxyz.append(v.ToXyz(True))
errorReport=[]
try:
	wireN=[]
	wireN.append(Autodesk.Revit.DB.Electrical.Wire.Create(doc,wiretypeid,viewid,wiringtype,verptxyz,sconn,econn))
	OUT = wireN
except:
	import traceback
	errorReport = traceback.format_exc()
	OUT = errorReport
for the wire type code:
# Import RevitAPI
doc =  DocumentManager.Instance.CurrentDBDocument
import System
wt = FilteredElementCollector(doc).OfClass(WireType)
wtn=[]
wte=[]
for w in wt:
	wtn.append(Element.Name.GetValue(w))
	wte.append(w)
OUT = wtn,wte
for wiringtype code:
# Import RevitAPI
import System
#Assign your output to the OUT variable
OUT = System.Enum.GetValues(WiringType)
and the final result is like this
Thank you so much.
I have modified something have look once is it okay?
find the attached dynamo script
best regards
Tanveer
in this way i strongly recommend to start the process run circuit by circuit … not for all categories at once … because it will be completed and hard to find errors … by practices you could find a better way to run all over the project
okay thank you
I successfully used your scripts, feeding points for creating the wire vertices (by using detail lines, then a node to Group them if they touch, then turn them to PolyCurves to get the vertex order right), the only problem i have is when i actually connect the wire to a device:
when the wire connects to a device the vertices at the ends of the wire will jump around somewhere between the 3d symbol of the device and the 2d symbol .
When you draw a wire in revit, connect it to 2 devices, the end Vertices will jump on the 2d / in the air / i don’t know where.
If you manually drag them, you can place them ANYWHERE and the wire will still be connected.
So after the wire is created in the Python Scrip and the Start and End Vertices “jump” onto the 2d symbol I want to adjust their position using Wire.SetVertex(Index, XYZ) to place them near the ends of the PolyCurve which provided the Vertices for creating the Wire.
Something like:
have Start & End vertex be set at the position (X+0.5, Y, Z) of the Start & End points of the PolyCurve from which the wire was created. So the wire will keep true to the PolyCurve which “generated” it. And cabling will be very nice and tidy.
I can get these X,Y,Z values from StarPoint and EndPoint node applied to the source PolyCurve, and try to set them using the XYZ(Double, Double, Double) constructor.
Since i cannot overlap 2 vertices i add 0.5 to the X value of the Start, End vertices extracted from the PolyCurve.
so:
Wire.SetVertex(0, XYZ(X+0.5, Y, Z)) - for the Start Point of the wire, index 0, X,Y,Z from XYZ constructor are extracted from the Start Point node.
then:
Wire.SetVertex(count, XYZ(X+0.5, Y, Z)) - for the End Point of the wire, count = wire.NumberOfVertices - 1, X,Y,Z are extracted from End Point of PolyCurve wire vertices were made from.
The results are laughable… i think the start vertex does not move / i don’t know / it acts in the same manner, but the end one goes Crazy, they radiate out from my area of devices , far away from the building… SO…definitely NOT working…
I am a noob in Dyn, zero xp in Python, but with some programming basic knowledge in Java…
And i kept going at this and cannot sort it … so please, this sounds like it is so easy to achieve, this would be my greatest work (by using other peoples’ python code… shame on me :smiley: )…
Here is a pic of the custom node (cause i take a list of PolyCurves and I want to process each one from the list):
Here is the code with the Wire constructor, where i attempt setting the positions of Start + End wire vertices i am not very sure how to format it here… :
    import sys
    import System
#IN[6] and below are all Lists…
newStartX = IN[6]
#the above X value has 0.5 already added to it
newStartY = IN[7]
newStartZ = IN[8]
newEndX = IN[9]
newEndY = IN[10]
newEndZ = IN[11]
    verptxyz=[]
    for v in verpt:
    errorReport=[]
    try:
    	w = Autodesk.Revit.DB.Electrical.Wire.Create(doc,wiretypeid,viewid,wiringtype,verptxyz,sconn,econn)
    	w.SetVertex(0, XYZ(newStartX[0],newStartY[0],newStartZ[0]))
    	lastvertIndex = w.NumberOfVertices - 1
    	w.SetVertex(lastvertIndex, XYZ(newEndX[0],newEndY[0],newEndZ[0]))
    	OUT = w
    except:
    	import traceback
    	OUT = errorReport
HI, I can’t find (Select Detail Item) in dynamo, please
thansks much
use ‘Select Model Element’ OOTB node (the node has been renamed in the graph)
THANKS, select model element
Hi Khuzaimah,
Would you please share your dynamo sample for this code?
Dear Sir this code only suitable for convert only one line to wire.
I try to convert multiple lines to wire but it’s convert like new one wire create connect each line end points. I attached image for your reference kindly give me solution for it sir.
just you need to iterate the code like this
import sys
# Import RevitAPI
import System
OUTr=[]
for i in range(0,len(verpt)):
	verptxyz=[]
	for v in verpt[i]:
	errorReport=[]
	try:
		wireN=[]
		wireN.append(Autodesk.Revit.DB.Electrical.Wire.Create(doc,wiretypeid,viewid,wiringtype,verptxyz,sconn[i],econn[i]))
		OUTr.append(wireN)
	except:
		import traceback
		OUTr.append(errorReport)
OUT = OUTr,len(verpt)
Dear Sir,
Line No. 59 have some issues. I given below,
File “”, line 54, in
TypeError: iteration over non-sequence of type Point.
This is line No. 59 - for v in verpt[i]:
Kindly help me to fix this warning sir
Dear Sir,
can you give the example dynamo code and nodes for converting detailed line to wire.
hi,
see the dyn below, make sure you set Dynamo to get the dyf files too.
how the script works:
select detail lines (ex. a lot of them, it takes the current selection so select all and filter “detail lines” of the type you use)
it will see which are touching (continuous lines)
convert them to polycurves
gets their vertices
uses wires constructor to generate wires from above vertices
finds 3d devices in a cuboid at start and end of polycurves
connect ends of wires to found devices
move start and end vertices of wires to start & end of polycurves.
the comments are in romanian but you should understand stuff just by watching the dynamo flow from left to right.
or translate the comments using google translate…
You will need some packages,like spring nodes, gorila 17, dynamo will complain, install them and it should be ok.
wires_from_detail_lines_rev1.dyn (61.1 KB)
WiresOnJointDetailLinePaths 9.dyf (57.3 KB)
moveWireEndVertices 4.dyf (28.8 KB)
