I’ve got two corresponding lists. One list of lines/curves and another of strings. The lines list eventually gets reordered in my graph and I need to get the strings list in the same order.
With something like text as my original and key list I can use List.MatchWithKeyValues to generate a set of values (I am using a range matching the index of the original list) that I can use in a List.GetItemAtIndex on the strings list to reorder them. The problem is the MatchWithKeyValues doesn’t work with lines.
DesignScript has an IsAlmostEqualTo function (?) that works but I don’t see a way I understand to do this in Python so… I’m wondering if we can translate the MatchWithKeyValues to DesignScript.
This just returns null;
def KeyValue(items:var[]..[],keys:var[]..[],values:var[]..[])
return = [Imperative]
lst:var[];
for (i in items)
c = 0;
for (k in keys)
if (i.IsAlmostEqualTo(k) && true)
lst = values[c];
return=lst;
c = c + 1;
You might be able to tell… I don’t really know what I’m doing yet. I just sort of hack away until I get something that works!
Of course, if there’s another solution I’m all ears! Thanks.
