Girls and boys,
I wanted to align family instances along a curve that i segmented because my families are 1.4m long. For the most part it went as it should, but at some points it didn’t aligned correctly. I’ve attached the dyn.
Girls and boys,
Is the family a line based generic model?
If so, this post might be of some help. Convert a line to geometry
No, it’s though generic model. And my point is that the family doesn’t align correctly. One vector from two points gives two different angles. How is this happening and why? And of course how to fix it.
@salvatoredragotta I do you one better (rvt attached). If you examen the output of the run you can see that some of the families are lying a bit skewed…
test.dyn (510.4 KB)
