thank you
I found a solution with explode twice (Thank you Mr. Vikram, for your availability and pugnacity)
cordially
christian.stan
Below is a DS function with the double explode.
Hopefully will work with your Dynamo version too.
def unEqOffset (pgn,dst:var[]..[])
crv = DSCore.List.Flatten(pgn.Explode().Explode(),-1);
cr0 = DSCore.List.ShiftIndices(crv.Offset(dst),[1,0]);
cr1 = cr0[0].ExtendEnd(cr0[0].Length*10);
cr2 = cr0[1].ExtendStart(cr0[1].Length*10);
pnt = DSCore.List.Flatten(cr1.Intersect(cr2),-1);
return Polygon.ByPoints(pnt);
UnequalOffset.dyn (9.0 KB)
Actually your ‘pugnacity’ needs appreciation ![]()
thank you guys,
I want to point it out that i cannot seem to offset all sides inside or outside. mainly due to -+ sign on each offset. Shouldnt offset work either inside or outside, besides that, the script works.
Negative value outside referent polygon
Cordially
christian.stan
