Using WindowsForm to pickpoint()
Hi, I dont know why click button, form not close()
must double click middle point of mouse then form close
Thank advance!
from Autodesk.Revit.UI.Selection import *
clr.AddReference('System.Windows.Forms')
clr.AddReference('System.Drawing')
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
from System import IntPtr
def sp():
    try:
        a = uidoc.Selection.PickPoint(ObjectSnapTypes.Endpoints,"Please select point")
    except:
        a = "NA"
    return a
class pickPoint(Form):
    def __init__(this):
        this.button1 = Button()
        #button1
        this.button1.Location = System.Drawing.Point(288, 129)
        this.button1.Name = "button1"
        this.button1.Size = System.Drawing.Size(150, 34)
        this.button1.TabIndex = 0
        this.button1.Text = "Please Pick Point"
        this.button1.Click += this.button1Click
        #Form1
        this.ClientSize = System.Drawing.Size(452, 196)
        this.Controls.Add(this.button1)
        this.Name = "Form1"
        this.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen
        this.Text = "pickPoint"
        this.ResumeLayout(False)
    def button1Click(this,sender,e):
        this.p = sp()
        this.Close()
form = pickPoint()
Application.Run(form)
OUT = form.p
Seem work fine
test pickpoint
Note:
in python the name of the parameter which corresponds to the instance is ‘self’ by convention not ‘this’
I Keep same code and changed “This” to “Self” but when click to button of Form, not get API menthod.
In the first time to click LeftMouse, not get API menthod. must press to scond time
If want Snap point before pickpoint I must press mid of mouse 2 times then can be snap points of element in Revit.
Last of video you can see, I used C# to pick point (result I can ObjectSnapTypes.Endpoints)
maybe there is a conflict with an add-ins, try to dispose the form at the end
Here an alternative with Hide() and Show()
test pickpoint2
def sp(form):
    form.Hide()
    try:
    except Exception as ex:
        print(ex)
        a = "NA"
    form.Show()
    return a
    def __init__(self):
        self.button1 = Button()
        self.button2 = Button()
        self._label1 = Label()
        self.p = None
        # label1
        self._label1.Location = System.Drawing.Point(30, 50)
        self._label1.Name = "label1"
        self._label1.Size = System.Drawing.Size(300, 23)
        self._label1.TabIndex = 0
        self._label1.Text = "Point : "
        #button1
        self.button1.Location = System.Drawing.Point(288, 129)
        self.button1.Name = "button1"
        self.button1.Size = System.Drawing.Size(150, 34)
        self.button1.TabIndex = 0
        self.button1.Text = "Please Pick Point"
        self.button1.Click += self.button1Click
        #button1
        self.button2.Location = System.Drawing.Point(30, 129)
        self.button2.Name = "button2"
        self.button2.Size = System.Drawing.Size(150, 34)
        self.button2.TabIndex = 0
        self.button2.Text = "Cancel"
        self.button2.Click += self.button2Click
        #Form1
        self.ClientSize = System.Drawing.Size(452, 196)
        self.Controls.Add(self.button1)
        self.Controls.Add(self.button2)
        self.Controls.Add(self._label1)
        self.Name = "Form1"
        self.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen
        self.Text = "pickPoint"
        self.ResumeLayout(False)
    def button1Click(self,sender,e):
        self.p = sp(self)
        self._label1.Text = "Point : {}".format(self.p.ToString())
    def button2Click(self,sender,e):
        self.Close()
form = pickPoint()
OUT = form.p
You are Idol !! :blush:
But as you said “maybe there is a conflict with an add-ins”, my code OK in my computer.
