Using two separator in a file name - Dynamo
Hi everyone, i am trying to develop a dwg export script with a custom naming, here the “current revision” part must be seperated with underscore ”_”, but i can’t figure out how it must be done, any help would be appreciated.
P.S.: i am new to this stuff so still trying to learn.:upside_down_face:
I like to use a Code Block in such cases
For example;
C = List.GetItemAtIndex(lst, 0);
M = List.GetItemAtIndex(lst, 1);
F = List.GetItemAtIndex(lst, 2);
C+"-"+M+"_"+F;
PS
You don’t need Element.GetParameterValueByName for each Parameter.
Thanks for your reply. Does this work for multiple views? Cause i did it and it gives me 1 outcome for one view, i need it for the all viewsets
Yes, but you have add Levels and Lacing
into the mix.
It worked, thank you so much
