Use/Load Rebar Shape using API
Hi All @c.poupin
In order to enable the use of rebar shapes in Architectural Template projects (as opposed to Structural Template projects), I’m using the code snippet below to either use an existing or load the 0-00 rebar shape from a local path (Rebar_path), as shown in the image below:
I tested my code in both Structural and Architectural projects. However, I’m facing two issues shown in the image below:
  • In the Structural Template project, where rebar shapes are loaded by default, I cannot retrieve the shape’s Name property.
  • In the Architectural Template project, the shape fails to load
import os
import System
from System.Windows.Forms import MessageBox
# Import Revit API
clr.AddReference('RevitAPI')
Rebar_path = r"C:\ProgramData\Autodesk\RVT 2023\Libraries\French\Structure\Formes d'armature\NF-P-02-016-1993\0-00.rfa"
def get_rebars_shapes():
    try:
        # get existing rebar shapes if a new "Structural Template" project is started
        collector = FilteredElementCollector(doc) \
            .OfCategory(BuiltInCategory.OST_RebarShape) \
            .WhereElementIsElementType() \
            .ToElements()
        rebar_shapes = [s.Name for s in collector]
        if rebar_shapes:
            return rebar_shapes
        # If no shapes exist "Architectural Template" project is started, try loading shape "0-00"
        if not os.path.exists(Rebar_path):
            MessageBox.Show("Rebar shape family file not found:\n{}".format(Rebar_path))
            return None
        with Transaction(doc, "Load Rebar Shape 0-00") as t:
            t.Start()
                MessageBox.Show("Failed to load rebar shape family.")
                return None
            doc.Regenerate()
            t.Commit()
        # Collect rebar shapes again after loading
            .ToElements()
        rebar_shapes = [s for s in rebar_shapes if s.Name == "0-00"]
        if not rebar_shapes:
            MessageBox.Show("Shape '0-00' not found even after loading.")
            return None
        return rebar_shapes
    except Exception as ex:
        MessageBox.Show("Error occurred:\n{}".format(str(ex)), title="Critical Error")
        return None
shapes = get_rebars_shapes()
OUT = shapes
Any help would be apreciated
Not sure why that property in particular is inaccessible, but you can just get the parameter values instead.
rebar_shapes = [s.LookupParameter("Type Name").AsValueString() for s in collector]
I switched to IronPython 2.7 engine and used this updated code, where I can this time get rebar shape Name property if I start a Structural Template project, however I still unable to load the shape I want if I start an Architectural Template project?
import os
import System
import traceback
clr.AddReference('System.Windows.Forms')
# Import Revit API
    try:
        collector = FilteredElementCollector(doc)\
                .OfCategory(BuiltInCategory.OST_RebarShape)\
                .WhereElementIsElementType().ToElements()
        rebar_shapes = [Element.Name.GetValue(s) for s in collector]
        if rebar_shapes:
            return rebar_shapes
            return None
            t.Start()
                return None
            doc.Regenerate()
            t.Commit()
        rebar_shapes = [s for s in rebar_shapes if Element.Name.GetValue(s) == "0-00"]
            return None
        return rebar_shapes
        print(traceback.format_exc())
        return None
OUT = shapes
Thanks.
I don’t see where you’re actually loading the rebar shape. You check to see if the path exists but that seems to be it.
You’re absolutely right!.. thank you for pointing out the mistake I overlooked!
Instead of writing if not doc.LoadFamily(Rebar_path): , I mistakenly repeated if not os.path.exists(Rebar_path): twice.
I’ve corrected the error in the updated code below, and it now works as expected.
import os
import System
import traceback
# Import Revit API
    try:
        # Get existing rebar shapes
        if rebar_shapes:
            return rebar_shapes
        # If no shapes exist, try loading "0-00"
            return None
            t.Start()
                t.Commit()
                return None
            t.Commit()
        doc.Regenerate()
        rebar_shapes = [s for s in collector if Element.Name.GetValue(s) == "0-00"]
            return None
        return rebar_shapes
        return None
OUT = shapes
Thanks.
