I’m currently looking for a way to delete all view templates from my model as easily as possible. I dont see myself deleting 100+ view templates one by one. I’ve managed to create a script to delete all filters but not one for deleting view templates. Could anyone advise?
There is a custom node from Clockwork package called “View.IsViewTemplate” use that to filter all your views thay contains view template. Then you can delete view templates which are not assign to views. Good Luck!
Thanks Kulkul,
I don’t just want to delete the ones not in use, I want to delete all. I can’t seem to figure it out. Is there a way then to remove all templates from my views then delete all templates not in use?
What do you mean by {“Is there a way then to remove all templates from my views then delete all templates not in use”}
What is your end goal? Delete all view templates or delete which one not in use?
To collect all view templates do this:
List<View> vtList = new FilteredElementCollector(DocumentManager.Instance.CurrentDBDocument)
.OfClass(typeof(View))
.Cast<View>()
.Where(x => x.IsTemplate)
.ToList();
Then to delete it you will have to make a list of their Ids and do this:
doc.Delete(e.Id);
Once you delete all view templates I don’t see how they would need to be removed from a view. There no longer will be anything applied to views. It doesn’t mean that your visibility settings will reset. They will stay the same as they were based on last view template applied. This behavior is the same with UI.
To delete all templates.
Thanks Konrad.
Just to check, the script, where do I insert this. I’m new to dynamo and have really only done the visual programming part. Plugging the code in will work too, I just need to know where to put it. I appreciate the help.
Ahh, in that case just run this code. I assumed you would know how to translate that to Python or ZeroTouch node. My bad.
# Copyright(c) 2016, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Import RevitAPI
clr.AddReference("RevitAPI")
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
if IN[0]:
try:
errorReport = None
allViewTemp = FilteredElementCollector(doc).OfClass(View).ToElements()
toDelete = []
for i in allViewTemp:
if i.IsTemplate:
try:
doc.Delete(i.Id)
except:
pass
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
errorReport = "Set input to True"
#Assign your output to the OUT variable
if errorReport == None:
OUT = 0
OUT = errorReport
Thanks @Konrad_K_Sobon. I ran it, however I did get a response:
File “”, line 34
SyntaxError: unexpected token ‘TransactionManager’
Ahhh the formatting got a little screwed up when I pasted it. Make sure that TransactionManager.Instance.EnsureInTransaction(doc) has the same indentation as TransactionManager.Instance.TransactionTaskDone() so hit TAB twice for the latter.
Hopefully this is the final problem. I made sure I deleted the indentation on both, then put 2 tabs in on both lines. But got the following… @Konrad_K_Sobon you’re a great help!!!
File “”, line 38
SyntaxError: unexpected token ‘’
I think that is what I did. Tell me if im missing something.
looks good now make sure they are TABS and not SPACES. Python is sensitive about this.
I’ve done eveything as you’ve said. Still no luck. I’ll try again on monday. Thanks again.
just take this. viewTemp.dyn (3.0 KB)
Worked like a charm. I’ll check where mine went wrong the first time. You’re a legend. Thanks for the help.
Great Job…Again
Both methods work fine. However would it be possible to only delete the templates not in use?
Cheers.
