Why doesn’t the unique items node work here or with the group by function node? (the 503.33333333 isn’t being culled) Does this have something to do with the repeating value? Is there any other error checking I can do to prevent this?
I think this is working correctly. You see 503.333333333 on the screen. But one value is likely 503.333333333332 and the other is actually 503.333333333331 - you just don’t that many digits on the screen. So they are unique - that’s why they are grouping into two separate groups instead of together. That said, if you were to put the values first through a String.FromObject, you might find that those would see only the digits shown and would be perceived as being the same.
