Unfold Wall
Dear all,
Does anybody have any idea how to unfold wall like the below one.
Also i saw it’s can be done but don’t how yet. check the video below.
Thank you
Anyone ?
Did you have a look at this?
http://dynamobim.org/dynamounfold/
it is OLD, but might give some idea’s
Or this one ?
https://forum.dynamobim.com/t/unroll-spiral-stair/10664/4?u=mjb-online
Is this something like that you’re expecting ?
P.S : I needed to approximate a little the curves to be able to draw them in Revit.
I had in the node DetailCurve.ByCurve, the error :
The multiplicities of other interior knots must be at most degree - 2. Parameter name: knots
@Alban_de_Chasteigner
Actually yes that is exactly what i need and question there is a node select by face so which face you are picking ?
I pick the floor but you can probably create a horizontal surface ex nihilo if you prefer.
In fact in my graph the wall isn’t unfold, it’s rather an elevation but you have a start.
Thank you man
This is a quite old thread, but recently I created a dyn for the job as below for one of my projects.
  1. create a plane unfolding surface by calculating height and length (using pi)
  2. translate necessary lines using uv (points at curved surface → uv → points at plane surface)
  3. generatel lines in selected view.
    You can watch how it works.
    https://youtu.be/z9swOX-asCU
