"Unevenly" curved isolines on a surface
Hi!
Is there an easy way to achieve this kind of effect with the isolines of a surface?
I hope the illustration is clear… the idea is to “push” the isolines around a hole, while leaving the rest of them straight. I was able to achieve a similar effect by selecting only one or several rows of points on a horizontal isoline and moving them along, by their UV coordinates and creating nurbscurves afterwards:
The next thing would be creating a formula, that is only selecting a number of points and generating a sequence, which would do the trick. I was just curious if there is an easier way to do that?
Here are the sample files:
Home.dyn (84.6 KB)
Project1.rvt (5.1 MB)
Hello, if you make a circle and determine from its center a deformation factor according to the center, (like a dart board and the points belonging to said zones) can be a track to dig
edit: If you have a faculty, you can imprint books (as a free listener if the faculty allows it) on flows and obstacles.
I had followed this kind of course at the time (with the equipotentials)
in fluid dynamics and also in soil mechanics
Cordially
christian.stan
On one of the machines I’m using lately I have a graph which utilized a few attractor points to deform points on a surface to generate openings like this… Will try to dig it up later today.
This should help with some ideas.
Attractors in linear path.dyn (31.3 KB)
Can be expanded upon to do stuff like this too:
Circular Weave With Attractor
Thanks, Jacob!
I modified it for my case, it’s exactly what I needed.
Thx for all the explanations in the code as well. I think it’s also worth having the deformationScaler as a slider, just to be able to play around with it. I’m now excited to experiment further with this graph
been playing around with this graph a bit :stuck_out_tongue:
I was just curious if it would be possible to create a more elliptical distortion, like that?
I suppose I should measure the vectors’ angles in the Python script and try to introduce an additional multiplier, depending on the angle, it’s the best approach I could think of at the moment
I think that would best be attained by weighting the distortion vector by the vector’s angle to the U (or V - not sure which direction things are oriented) isoline vector.
Something like weight = (90-angleToIsolineVector)/90*weightingFactor
I tried it and it seems to work :slight_smile:
Here’s how i modified the code:
basePntRows = IN[0]
attractorPnts = IN[1]
maxAttractionLen = IN[2]
deformationScaler = IN[3]
ellipticalFactor = IN[7]
isoVectX = IN[4]
isoVectY = IN[5]
isoVectZ = IN[6]
isoVector = Vector.ByCoordinates(isoVectX, isoVectY, isoVectZ)
newPntPaths = []
angleslist = []
for basePnts in basePntRows:
	newPnts = []
	for bPnt in basePnts:
		baseVects = [Vector.ByTwoPoints(aPnt, bPnt) for aPnt in attractorPnts]
		summedVect = Vector.ByCoordinates(0,0,0)
		for vect in baseVects:
			angle = math.degrees(isoVector.AngleWithVector(vect))/100
			angleslist.append(angle)
			ellipticStretch = (90*ellipticalFactor)/(90-angle)
			if vect.Length > maxAttractionLen: scale = 0
			else: scale = (maxAttractionLen - vect.Length)*deformationScaler*ellipticStretch
			scaledVect = vect.Normalized().Scale(scale)
			summedVect = summedVect.Add(scaledVect)
		newPnt = bPnt.Translate(summedVect)
		newPnts.append(newPnt)
	newPntPaths.append(newPnts)
OUT = newPntPaths, angleslist
I added as many things as inputs, as possible :slight_smile: it needs a bit more tweaking though, but it’s getting closer. Thx again
