Unable to Install Synthesize toolkit
I installed the package and it asked if I want to install “required extra files” and I clicked yes but this error popped up and when I again tried to install though the installer node, same issue occured.
@rajeshjamariya16
Hi @rajeshjamariya16 not sure but when we install from Pmanager…in newer version of synthezise, you will get the option to install “the extra” without do it inside the node…have you seen that or have try that?
Hi, as I mentioned I did that but got the error and again when I tried to install though the node, got the same error, I also uninstalled the package and reinstalled multiple times with no success.
the extra folder!
I installed a much older version and it works.
