Hi all, A very good evening.
I am trying to get UI based on pop up after the postable command completes like after the user clicks on last command of “close” of postable command of inteference check then the UI pop up should appear. Every time if run it, the UI will pop up first and then the postable command is opening. Can anyone help for this ? I know I am missing a lil bit but need a help for this.
Below is the image after which the user clicks on “close” button then the UI should appear
Thanks in advance
Below is the graph that I am working on:
