Two out ports
When i open a Dynamo which i created few days back, i find two OUT ports in Color Picker Node. Can anybody knows the reason?
Hi @SHIBUJOSE,
You’re using Dynamo 2.x so use instead the out of the box node Color Palette.
I noticed the same behavior on other nodes. Does anyone know the reason?
Every time I’ve seen it the root cause has been an conflicting Revit add-in. Disable all your Revit add-ins and see if that resolves things. if not generate a new topic as this is a bit old. Be sure to attach your Revit journal and Dynamo log if you do so.
