Hey Everybody!
I’m having some trouble with the function “List.GroupByKey” in definitions, it only return nulls for each list.
When I’m trying the same thing in a code block it works fine.
Anyone who knows what I’m doing wrong?
Hey Everybody!
Hi @jgu,
Maybe you have to transform the value from the Element.ElementType into a string before you can use it as a key.
Kind regards,
Mark
@jgu You don’t need a function, actually.
With nodes, you could do this …
However, your function has a few issues.
The one below provides some output, not the desired one
But should help you identify the issues in yours.
THANK YOU SO MUCH!!! - or in danish: TAAAAAAK!!!
That was exactly what I needed, everything is working as I wanted it
