Hello~~
Is there a way to handle walls that intersect with Steel Beams? For concrete beams I can Join, but steel beams cannot be done
Any help is appreciated, thanks.
Could you please check if it’s possible in Revit to join a steel beam and a wall? If it’s not possible in Revit, then Dynamo won’t be able to do it either.
sjafarali75 is correct, this is a Revit question and (I think) it relates to “Material for Model Behavior” family parameter. You could try changing this to “Concrete” but that will also remove the other functionality of “Steel”.
https://help.autodesk.com/view/RVTLT/2022/ENU/?guid=GUID-97DE744A-CDC8-45D3-9963-BAA7C721F1CD
