Transfer Project Standards - Postable Command
Hi Everyone,
I’m not finding many results on this topic, so I need to start a new topic.
Is there a way to transfer project standards via dynamo? At the very least I would like to queue the user to transfer project standards.
I am running anywhere from between 5-10 consecutive scripts in order to standardise external models according to our data structure and project standards.
If I knew how to use python, I wouldn’t have to ask. :frowning:
Cheers,
Matt
I think I was able to answer my own question.
My previous issue was purging unused elements, to which I was able to use a code snippet from here. Because purging is typically recursive, I could just string 3-4 python scripts to run consecutively.
Anyways…I just took the code for purging and modified the command to “ID_TRANSFER_PROJECT_STANDARDS”
it turns out that postable commands are pretty damn intuitive.
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitAPIUI’)
from Autodesk.Revit.UI import RevitCommandId
from Autodesk.Revit.UI import UIApplication
from Autodesk.Revit.UI import ExternalCommandData
RunIt = IN[0]
if RunIt == True:
CmndID = RevitCommandId.LookupCommandId(‘ID_TRANSFER_PROJECT_STANDARDS’)
CmId = CmndID.Id
uiapp.PostCommand(CmndID)
errorReport = ‘Success’
errorReport = ‘Set IN[0] to true’
#Assign your output to the OUT variable
OUT = errorReport
Hey @m.owens,
where can i find a list of all Postable commands like "ID_TRANSFER_PROJECT_STANDARDS”
Okay, thanks. But i am missing the command “ID_PLAYLIST_DYNAMO” to access Dynamo Player. How do i find that one?
Hi Laurin,
Ich am by no means a Postable Command Expert.
Here is what I found by searching “Playlist”
okay thanks @m.owens
and if i want to give it a list of the categories i want to copy without the menu?
