Titleblock Parameters
HI All,
Learning Dynamo to automate few items helps more in setup. Our current setup is once central MEP model. Trying to automate to punch in some string initials under Drawn, Verfied some other attributes. Stuck at this point where the list needs to be converted into elements I believe. Is there a node that can achieve it ?
You need to pass the element list in the filter by boolean mask, not the parameter values.
Then you can go on
