I read that the node doesn’t work with negative depths.
So I wanted to move the solids in the opposite direction.
But the translate wont work for me. They don’t move.
Is it maybe because the conversion from geometry to objects, several tried but always with a yellow message. Has someone maybe a solution?
@pieter.souvereyns you need to use a coordinate system to serve as the transform matrix for the Object.Transform node.
