TextNote Add Leader by points
This is I would do it:
  1. Search the method in the revit api docs:
    AddLeader Method
  2. Find information about the “Leader”:
    Elbow Property
    End Property
  3. Look for some examples in the revit api forum:
    Solved: CREATE LEADER - Autodesk Community
  4. Convert the code into python:
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
textNote = UnwrapElement(IN[0])
for i in range(1,5):
    leader = textNote.AddLeader(TextNoteLeaderTypes.TNLT_STRAIGHT_R)
    leader.Elbow = XYZ(15, -0.75, 0)
    leader.End = XYZ(15, 5+i*2, 0)
OUT = "Done"
Hope it helps
