I’m changing the width on text and then trying to get the new height. However, the height doesn’t change until after all the Dyanmo nodes have run. See two lists from code below. both oldHeight and newHeight area the same. I’m guessing Dyanmo’s transaction manager isn’t “really” committing the changes on TransactionTaskDone?
import System
#from System.Collections.Generic import *
# Import RevitAPI
clr.AddReference("RevitAPI")
from Revit.Elements import *
myElements = UnwrapElement(IN[0])
width = IN[1]
newElems = []
myOut = []
oldHeight = []
newHeight = []
#from Autodesk.Revit.DB import Transaction
#t = Transaction(doc, 'Name')
#t.Start()
for i in myElements:
oldHeight.append(i.Height)
i.Width = width
i.HorizontalAlignment = Autodesk.Revit.DB.HorizontalTextAlignment.Left
newElems.append(i)
uidoc.RefreshActiveView()
#t.Commit
for i in newElems:
myOut.append([i.ToDSType(True), i.Height, i.Coord.ToPoint(), i.Coord.X, i.Coord.Y, i.Coord.Z])
newHeight.append(i.Height)
OUT = myOut, oldHeight, newHeight
