So we are an MEP Contractor.
How to go about a dynamo to check if the Arch, Structural models have been detached from central WITHOUT actually opening the model?
You can’t check the contents of a file without opening it.
Seconding what @jacob.small said.
Dynamo works on the basis of the already opened Dynamo file. No real way around that, that’s how the entirety is set up.
You could attempt to gather the data via a background open, but corruption would be a possible result and there wouldn’t be more than a half second’s worth of time saved.
Actually it is possible using the Revit API without fully opening the document. Example function in python:
def IsLocalModel(revitFilePath):
isLocalModel = False
basicFileInfo = BasicFileInfo.Extract(revitFilePath)
if basicFileInfo is not None:
isWorkshared = basicFileInfo.IsWorkshared
if isWorkshared:
# NOTE: see: https://forums.autodesk.com/t5/revit-api-forum/basicfileinfo-iscreatedlocal-property-outputting-unexpected/td-p/7111503
isLocalModel = (basicFileInfo.IsCreatedLocal or basicFileInfo.IsLocal)
return isLocalModel
This IsLocalModel() function will tell you whether or not the file is a local file (if it’s not it’s either detached or a non-workshared model).
