TaskDialog Problem in Revit 2023
@Amr.Omara
If you have little experience with .Net Reflection, this can be useful to get around problems of Overloading
an example
#clr.AddReference("System.Reflection")
from System.Reflection import BindingFlags
from Autodesk.Revit.UI import (TaskDialog, TaskDialogCommonButtons,
                               TaskDialogCommandLinkId, TaskDialogResult)
title = 'Task Dialog Title'
dialog = TaskDialog(title)
# Properties
dialog.MainInstruction = 'Text Header'
dialog.MainContent = 'Text Content'
dialog.FooterText = 'Footer Text'
dialog.VerificationText = 'Verification Text'
# dialog.ExpandedContent = expanded_content
# Add Button
dialog.CommonButtons = TaskDialogCommonButtons.Ok | TaskDialogCommonButtons.Yes
# Set Default Button
dialog.DefaultButton = getattr(TaskDialogResult, "None")
# Add Command Link
dialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink1,
                      'Command Button Text',
                      'Command Button Sub Text')
dialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink2,
                      'Command Button Text 2',
                      'Command Button Sub Text 2')
#result = dialog.Show()
# Example 1 with InvokeMember
arguments = []
invokeObj_1 = clr.GetClrType(dialog.GetType()).InvokeMember("Show", BindingFlags.InvokeMethod , None, dialog, arguments)
# OR
filter = System.Predicate[System.Object](lambda m : m.Name == "Show" and len(m.GetParameters()) == 0 )
invokeMethod = List[System.Reflection.MethodInfo](clr.GetClrType(dialog.GetType()).GetMethods()).Find(filter)
invokeObj_2 = invokeMethod.Invoke(dialog, None)
OUT = invokeObj_1, invokeObj_2
