TaskDialog infront of dynamo player (foreground)
Hey guys,
some of my scripts are using the taskdialog to inform the user about issues. Unfortunately the taskdialog opens behind the dynamo-player. Is there an opportunity to show it infront of the dynamo player? I don’t want to drag the dynamo-player before executing.
Thanks for your help in advance :slight_smile:
I think Dynamo and the Dynamo Player are programmed to be always on top.
What does your dialog box look like? It’s hard to help you without more information.
Hello
You can try to reduce the window player at start with user32 API
reduce_player2
import sys
import System
clr.AddReference('RevitAPI')
#import Revit APIUI namespace
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append(pf_path + '\\IronPython 2.7\\Lib')
import ctypes
titleproject = doc.Title
windowPlayer = ctypes.windll.user32.FindWindowW(None, titleproject + ".rvt - Lecteur Dynamo")
if windowPlayer:
	hWndParent = windowPlayer
	SW_MAXIMIZE = 3
	SW_MINIMIZE = 6
	ctypes.windll.user32.ShowWindow(hWndParent, SW_MINIMIZE)
	dial = TaskDialog("Info")
	dial.MainInstruction = "Player has been reduced"
	dial.Show()
Need to adapt this line with your language
@c.poupin always coming with the random Python diamonds!!!
This looks so so so useful as often we run into the issue of users losing task dialogues behind player and thinking the script is stuck.
Going to incorporate this code into our popup node so that by default it minimises player for people.
Cheers
@c.poupin
That’s a really nice solution. I bet with “SW_MAXIMIZE” you can maximize it again after the user confirmed the taskdialog :+1: via the result of taskdialog.
Just wanted to show another method I use a bit using Winforms and the self.TopMost variable.
dnkJxYm5va
clr.AddReference('System.Windows.Forms')
clr.AddReference('System.Drawing')
from System.Drawing import *
from System.Windows.Forms import *
from System import Array, Object
class SimpleForm(Form):
    def __init__(self):
        # The text to show in the top bar
        self.Text = "A Dialog with Information"
        # The width of the form in pixels
        self.Width = 500
        # The height of the form in pixels
        self.Height = 240
        # Make the form a fixed size
        self.FormBorderStyle = FormBorderStyle.FixedDialog
        # Position the form in the center of the screen
        self.StartPosition = FormStartPosition.CenterScreen
        # Bring the form to the front of all windows
        self.TopMost = True
        # Show top bar controls
        self.ControlBox = True
        self.MaximizeBox = False
        self.MinimiseBox = True
runMe = IN[0]
if runMe:
    # Create the form
    form = SimpleForm()
    # Run the form
    Application.Run(form)
    OUT = "Set RunMe to True";
Also a really good solution, but I think I will stick to minimizing and restoring the dynamo player window. :+1:
