I am writing my first python code. My current python code sets the auto scale of the blocks inside the table cells to false. It then scales the blocks inside the table cells.
What I need help with is the last step. I need to edit a table block attribute value. I believe I can use Table.SetBlockAttributeValue but I am having a hard time getting the objectid. Any ideas on how I can get an objectid by the name of the attribute?
Here is the dynamo and code for reference. My Python script is at the end.
SUE Pothole Table_V7.dyn (160.9 KB)
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
RowIndex = IN[0]
ColmIndex = IN[1]
table = IN[2]
isFalse = IN[3]
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Database as db:
for i in range(2, RowIndex + 1):
acTable = table.InternalDBObject
acTable.UpgradeOpen()
acTable.SetAutoScale(i, ColmIndex, isFalse)
acTable.DowngradeOpen()
acTable.SetBlockScale(i, ColmIndex, 0.06)
acTable.SetBlockAttributeValue(i, ColmIndex, DIAID, "value")
# Commit before end transaction
t.Commit()
OUT = table
