Surface outline without inserts | Room Geometry Outline
Hi :slight_smile:
I got a surface with some cutouts, but I just need the outline. The surface was extracted from Room → Element.Geometry → Bottom Face and has no intelligence.
Everything I get with Surface.PerimeterCurves is a list of all curves, but I just need the outline, without any inserts.
Is there a way to extract the outline from a rooms bottom face with inserts?
In this thread Surface Outline without inner cutouts / holes / whatsover maciek.glowka had a great solution which worked for floors, but I can´t get it to work with rooms.
The “normal” Room.Boundaries does not work, because the Model ist Linked and got a linked facade inside that model. Even with attaching the facade model etc… Room.Boundaries spits out incorrect results.
Kind regards, Jannis
Hey :slight_smile: I solved it myself by “sorting” the curve groups together. This was a bit annoying :slight_smile:
This is my final code for an input of a list of list with curves.
# Phython-Unterstützung aktivieren und DesignScript-Bibliothek laden
data = IN[0]
log = []
outCurves = []
for roomCurves in data:
    currentCurve = roomCurves[0]
    i = roomCurves.index(currentCurve)
    del roomCurves[i]
    outList = []
    run = 0
    list = []
    list.append(currentCurve.StartPoint)
    while len(roomCurves)>0:
        run+= 1
        end = currentCurve.EndPoint
        found = False
        for y in roomCurves:
            start = y.StartPoint
            dist = start.DistanceTo(end)
            # outList.append(dist)
            if dist == 0:
                list.append(start)
                currentCurve = y
                ind = roomCurves.index(y)
                del roomCurves[ind]
                found = True
                break
        if found == False:
            outList.append(list)
            del roomCurves[0]
            list = []
    outCurves.append(outList)
OUT = outCurves
