I am trying to set a parameter in my wall types that reads the thickness and material of each layer of the wall construction. I am able to do this for one wall at a time (see attached) but I would like to be able to just hit run and it will go through all my wall type in my project.
That image is too small to see any detail. Can you zoom into a node so we can read the text and then use Dynamo’s built-in screen capture tool?
Without looking I’m going to guess it has to do with which level of the lists various nodes are operating on.
Thanks for the tips, i will give it a try right now.
Did you make it? I’m trying to do the same thing.
Hi @remigiuszCNFU2 and welcome to the forum
this post is almost 7 years old, try create a new and show all what you have tried so far…
