I have 95 elements for all of the given lists in the Code Blocks. I want to connect the 1st element of the 1st list with the 1st element of the second list and so on.
As a result, I need 95 list, created from my initial 8 list (containing 95 elements each)
Thank you for your answer! Sry for being uncomprehending, but i still don’t get it.
I’m pretty sure, i know the basic uses of these nodes, but still, i have no idea about using them here.
Which list should i transpose here?
If i traspose the result, nothing changes.
If i transpose the initial lists, still nothing changes.
Exactly! Thank you!
Is there an article or something about node lacing? This is the first time, i saw them used, and I don’t really understand them yet.
