'String.Insert' node - Meaning of index
Hi all,
Wondering if someone can help me understand what ‘index’ is doing as part of the 'string.insert node?
I use zero as that is what I found to work, I have experimented with changing the number as I orginally thought it was referring to the item listed, and was a start point, but it does something wierd to my numbers if I change it to say… 2. …eg: 60A0 ???
trying to understand one node at a time! Thank you for your help.
Consider the string “DYNAMO”
Here, the index of D is 0, Y is 1, N is 2 …
Can this go right to left? I’ve tried feeding it negative numbers but that didnt seem to work :frowning:
To work backwards, you could subtract a positive number from the value of String.Length.
