Spring.CurveLoop.Simplify
I would like to take the block,
but it take an empty list??
U can use the flatten node after the BoolMask
Or use list at level feature if you need to maintain the data structure.
the problem is not because its not flattend its because closed curve is not satisfied…
and ofcourse you have to flatten the node if you will not going to do any mask or list operation with the first output. and try making polycurve from joined curves or try any other way you know to create closed curve
i make an update from the notes BVN,
and now it watch like this…
The curve i complete…I didn’t Change anything…
