Hi all,
I am trying to place sopt elevations in a plan view but its not working for me. I have tried to debug this but can’t able to figure it out.
can anyone please tell me where I am going wrong ?
The following pic explain where I am upto !!
The python code follow as below:
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import Document, XYZ
# Unwrap inputs
view = UnwrapElement(IN[0])
refs = UnwrapElement(IN[1])
origins = UnwrapElement(IN[2])
bends = UnwrapElement(IN[3])
ends = UnwrapElement(IN[4])
leader = UnwrapElement(IN[5])
spot_type = UnwrapElement(IN[6])
elementlist = []
try:
for ref, pt, bend, end in zip(refs, origins, bends, ends):
spot = doc.Create.NewSpotElevation(view, ref, XYZ(pt.X, pt.Y, pt.Z), XYZ(bend.X, bend.Y, bend.Z), XYZ(end.X, end.Y, end.Z), XYZ(pt.X, pt.Y, pt.Z), leader)
elementlist.append(spot)
if spot_type is not None:
doc.GetElement(spot.GetTypeId()).ChangeTypeId(spot_type.Id)
OUT = elementlist
except Exception as ex:
OUT = "Error: {}".format(str(ex))
