Spot Coordinates by Point
Which node can give me the values of this Dimension output
Revit.Elements.SpotCoordinate.dyn (14.8 KB)
I have to fill these values to another parameter for scheduling.
if you connect your watch node to the Point output of your Element.Location+ node, you should see co-ordinates rather than dimensions.
Currently, you are just watching the spot co-ordinate item rather than the point itself.
sorry forgot to mention,
I want these coordinates from Survey Points
Hi try dimension origin from rhythm or dimension properties from Genius Loci
@sovitek
keep in mind that point is from origin…so if you want from survey or PBP there doesnt share point with origin…something could probably help…
thank you @sovitek
