Hello, how are you, I have a little doubt how I can order the list using only the first index
the new list should be in this order
Add this line to your output.
output.sort(key=lambda x: x[0], reverse=True)
it remains 0, why?
nums = [[10,"al"],[3,"Martin,"],[3,"Distrito"],[2,"cual"]]
OUT = nums.sort(key=lambda x: x[0], reverse=True)
I expected it to be Tuples. For lists in lists:
OUT = sorted(nums, key=lambda x: x[0], reverse=True)
You can just use nums.sort(reverse=True)
. The part you’re missing is that list.sort
does not return anything, it only modifies the list. So you have to call list.sort
for nums
but then return nums
in your OUT
statement.
EDIT: The problem that I think you’re going to have is that you’re currently not considering sublists with the same key (zero index). For example, [2,"cual"]
and [2,"Distrito"]
are “out of order” because the sorting is respecting the initial list order.
