Sort the curves into two lists , one with x direction and other with y direction.
Reason for getiing that irest is to select a longest side of both direction of a finish slab to place tile start point.
Need some advice guys
Thank you
You have the direction, which is a vector. Vectors have components like X and Y. You can check a vector’s X or Y with Vector.X or Vector.Y respectively.
If you want a vector that goes only in the X direction, and not in the Y direction, that would mean a vector with some value that is not 0 in the X, and 0 value in the Y.
