Sort By Index
I am trying to take a created List and Sort by Index of each Sub list. I can get the result by GetItemAtIndex, but need to repeat for each Index. So all the Index at 0 is a list, all the Index at 1 is a list and so forth. The list could change in amounts, in this case there are 4 per sub list, but could change to less or more. Hope I described this correctly and the screen shot helps.
List.Transpose is what you want.
You may have to play around with the Level@ input and/or throw in a flatten at a specific level first as your list is double nested (actually, using list.join instead of list create might fix that too).
You da man! Final results is to use this data for inputs into a Key Schedule. Thanks.
List.Transpose
