Hi everyone,
how can I sort two lists using the first one?
For example,i have:
A 1
K 4
C 2
B 6
and I need:
A 1
B 6
C 2
K 4
Hi everyone,
For example,i have:
A 1
K 4
C 2
B 6
and I need:
A 1
B 6
C 2
K 4
Use a List.Sort node.
1 - please share your dynamo graph
2 - please explain what is not right.
That sort looks good to me apart from you have a number 30 at the top.
Where do you want the number 30 to be?
If you want it to be listed under “H” then the fastest solution would be to call it Heat output 30% efficiency rating.
I think you’re saying you want to keep the list structure?
Have you ticked the list structure box?
I’ve tried this way, but it doesn’t work.
Not sure I understand what you are after, but it sounds like List.SortByKey should work here. The list input is the columns for all the data. The key input is the value you want to sort by. Set both to @L2 and use longest lacing.
Longest lacing with both @L2 might have resolved it as well, but no need to reinvent the wheel here. Glad you’re sorted out. ![]()
