I’m trying to make a sum, almost like a VLOOKUP in Excel… according a element.id.
I’m almost certain someone can pull this off with OOTB nodes, but I need python for this:
listin = IN[0]
ids = [x[0] for x in listin]
idset = set(ids)
diction = {}
for id in idset:
diction[id] = 0
for x in listin:
diction[x[0]] += x[1]
OUT = diction.keys(), diction.values()
Hey,
I think you answered another topic that i posted kkkkkk…
I posted two topics in almost the same time, but differentes topics
Anyway, thanks, to the other topic it working!
Haha okay, I see, but it’s basically the same question right?
No,
This topic is about 2 lists, the other, is about only one.
I helped me with the other, but in this situation, i didn’t find a way yet…
Ah yes now I see.
If you can get your keys and values aligned like this:
Then you could use the attached python code.
Sum across lists by key.dyn (11.1 KB)
20170809-2.dyn (9.9 KB)
I’m sorry,
I wrote wrong… is almost what you did, but, i forgot to say that, the second list, can be have two or more equal elements, example below:
Not sure, if I understand the intent, maybe something like this…
20170810-1.dyn (13.2 KB)
Not working…
but, dont worry, i made by another way, a lot of nodes bot it’s working… hahaha.
Thanks a lot!
@daniel.petrin Hello, I have a similar problem. Can you show me how you solved it?
