Hi @talbimam,
You have a nested list of solids so i think you have to add “levels” to the Solid.ByUnion node.
For more information see http://dynamobim.org/introducing-listlevel-working-with-lists-made-easier/
Kind regards,
Mark
hello @MJB-online i’ve just tried it but it gives me the same amount of solids ! still no union
@MJB-online i want to find any solution to get the area of windows and doors with complexe geometry (not width x height method) (eg: windows and dorrs with arc) any idea to start ?
Hi @talbimam,
It works for me (your initial question).
Maybe someone else can help you with your next question, i have to leave (my Dynamo computer) now.
Kind regards,
Mark
you can try flattening the list it should give you a single solid
@MJB-online i think that the problem comes from the solids of the windows ! Thank you
@SouravGanguli thank you but i don’t think flattening will solve the issue.
If you want to end up with just one solid from both (sub)lists, you can try to set levels value to 1 (instead of 2).
Kind regards,
Mark
