Update v2.1
DS_snow_flake_v2.1.dyn (148.7 KB)
Awesome work! How many will you be printing?
Ooo, what an awesome idea! Our 3D printer at work is gathering dust
I built mine live today during the Dynamo Office Hour Community Conversation, which will be posted to YouTube later (we have to wait for the recording to process).
Took it a bit farther and decided to make it snow… rather happy with the result:
Are you going to share the falling snowflake graph?
Not really in a ‘shareable’ state as there aren’t any annotations and it needs a custom node to make it work, but I’ll see if I can come up with a distribution method.
For now you can check out how each single snowflake was built here: 21 - Community Conversation - Dynamo 2021 Wrap Up! - YouTube
Yeah, I’m defo a tad obsessed… Been ill all day but wondering, “wonder how it’d work with an L-system”…
So after my lemsip (lemon drink with asprin and stuff)… I did this:
Also shoved it into GD too (first time I forgot to limit the iterations and killed it… )
one of those looks like the flux capacitor.
We should stick to physics
There is six dendrites If there are any.
Still asking myself questions about the stick-like ones though.
I told my last one to repeat in angles of 60 degrees… No idea why it’s in fifths… Must be aliens or something
That’s because I had 1/6 to start and I wanted 5 more…
But obviously the 360 is the same as the one I was copying…
I should have written 60…300…#5
I need to walk away from these snowflakes
My first one… I inverted the cuts to be the bits that showed… Don’t think it’s as good as the L-System one but it’s still fun :
Snowflake4.dyn (103.4 KB)
from some post ideas and python code on this topic
Note:
Start script first in manual mode (to generate geometry) then activate periodic mode
enjoy all !
BIM 2021 snowflake_v4 forum.dyn (52.4 KB)
Are you meant to run it on automatic or periodic?
I just tried periodic and it’s killed my pc.
Start it first in manual mode (to generate geometry) then activate periodic mode
I was used dynamo 2.13
Ah, I’m using Revit 21/ Dyn 2.6.1 … maybe that’s why.
